404T to 466
Deere Puller
07-25-2004 18:38:35
Hello fella's:
I have a 404T engine from a 7700 combine that I'm going to rebuild towards the end of the summer and want to know if there's anything I can do internally to make it more powerful. Can I install 466 sleeves into this engine or is that impossible?
Thanks!
4020dt
07-27-2004 08:18:56
 Re: 404T to 466 in reply to Deere Puller, 07-25-2004 18:38:35
466 sleeves won't fit , just too big as mentioned below . Anything can be made to fit though for $$$$$$$ , but if you want to go to 466 it would be cheaper to find a 466 block . 404 head will fit 466 block , and 466 blocks were made with A or P pump mountings . Late 404 heads , mid'76 and on , the ones with KDEL injectors , are the same head as used on 466's .
Same crankshaft for both , different connecting rods , 466 has bigger wrist pin and a couple different designs . OEM camshaft is same for all 404 & 466T and A engines , different than non turbo engines . The Predator Kit as mentioned is a good way to go but somewhere I heard they aren't available now , maybe that isn't so but that's what I heard .
HTR
07-26-2004 16:10:12
The 466 sleeves won't fit, too big outside. Reliance makes a predator kit, different cam, and different pistons for the 404. A lot of the heads will interchange, but I don't know if it helps any.
G-MAN
07-27-2004 10:46:23
 Re: Re: 404T to 466 in reply to HTR, 07-26-2004 16:10:12
Yep, you're right. I went back and checked EPC and found that it's the 4040 that used the same part number block as some 7700s, not the 4440.
G-MAN
07-26-2004 10:54:05
I've never done it personally, but I think the 466 sleeves will go into the 404 block - a check of EPC shows the same part number block used in some 7700 combines also used in the 4440 tractor, which is a 466 engine - and you'll then have a 466 as the strokes are the same. However, you're going to have to make sure that you use the right piston in order to come up with the proper compression ratio. One of the 7700 replacement cylinder head numbers ALSO crosses to the 4440 and a bunch of other 466-powered machines, so I would THINK that you could possibly install 4440 pistons and sleeves and be okay. But, that is all supposition and by no means a guarantee.
