AR and BR's
ERIC
07-25-2004 11:06:56
I need some info on a STYLED AR (after '49) and a BR.
What kind of price range am I going look at on each?
What is the estimated weight of each?
What is the horsepower of each?
What are some of the pros and cons of each as far as mechanical wise?
I would like to restore a Styled AR and my grandad would like to restore a BR on steel.
Thanks
ERIC
bent
07-26-2004 08:38:40
 Re: AR and BR's in reply to ERIC, 07-25-2004 11:06:56
Eric, my first JD tractor was an styled AR. I have completly disassembled it and am slowly working to put it back together. For my first project, I think it was an excellent choice. Mine has a WICO X mag. They are a simple machine and quite easy to get parts for and I think they look sharp when restored or in good original condition. I also have a low-seat 60 which is similar. Expect to pay $1,000 up to $3,000. My manual says it weighs about 4800 pounds dry and it is supposed to have 35HP. Can't help you on the BR's, but they are a neat little tractor, smaller yet than an AR and an excellent choice for a first-time restoration. I have about 200 pics of the AR restoration if you are interested.
Brent
ERIC
07-26-2004 09:59:56
 Re: Re: AR and BR's in reply to bent, 07-26-2004 08:38:40
Bent,
I would be interested in those pictures! Im glad that I found someone that is currently restoring an AR. I would like to restore an AR and not find one already restored. So I would be interesteed in seeing those pictures. Have you found any major problems while restoring the AR? Just want to ask so I know what I would be getting myself into!
Did those tractors originaly come with the WICO X mag?
Hope to see the pictures!
Thanks
ERIC
Bent
07-26-2004 13:57:08
 Re: Re: Re: AR and BR's in reply to ERIC , 07-26-2004 09:59:56
Eric, I didn't find problems unique to an AR, I think the problems I ran into could be found in almost any 2-cyl. I found that 1st and 3rd gear need to be changed. There was another post below that suggested these tractors spent alot of time in 3rd. I would agree. When I initally got it running, it did some work around the farm and spent alot of time in third! An AR is a tough old no BS tractor. Alot of them were used for long days of some sort of tillage so watch your rear axle bearings. Watch the fender brackets for rusting through, I believe AR's were bad for filling the bracket up with dirt, which would then speed up the rusting process.
I think you could get an AR with either a WICO XH magneto or a distributor/coil. My '49 has no key or ignition switch, you simply pull the throttle back to stop the engine. I also have a '53 that I wrecked that had a key and distributor/coil AND it had a water pump.
ERIC
07-26-2004 18:28:48
 Re: Re: Re: Re: AR and BR's in reply to Bent, 07-26-2004 13:57:08
Bent,
You didnt mention anything about the 200 pictures that you have?! Thank you for your encouragement on getting an AR. I am going to have to go search and look for one! Thanks for replying to my followups. Let me know about those pictures!
Thanks
ERIC
bent
07-27-2004 07:57:52
 Re: Re: Re: Re: Re: AR and BR's in reply to ERIC, 07-26-2004 18:28:48
Eric, if you get me an email address I can send you some pictures. I noticed an AR on deeresofyesteryear.com for $3,700. This might seem like alot, but a wreck will cost you 1000-1500 and you can easily spend 3000 just to get it to the point where it is the same as the one for 3700. Don't buy a wreck, spend a little extra and get one you work on a bit and have running. Consider a wreck for you second project.
Brent
ERIC
07-27-2004 18:56:02
 Re: Re: Re: Re: Re: Re: AR and BR's in reply to bent, 07-27-2004 07:57:52
Bent,
I dont feel too comfortable giving my email address on the discussion board. I tried to go to your email but saw that you had hinden it from spam generators. Maybe we can figure something out about those pictures. I did go and see that AR on deeresofyesteryear.com. I didnt really like it that they didnt have any pictures of that tractor. Someone though is selling a STYLED AR on ebay right now and it doesnt look too bad. I might look into it! It looks like all it needs is a paint job and a back seat cushion!
Let me know what your thinking!
Thanks,
ERIC
bent
07-28-2004 08:50:26
 Re: Re: Re: Re: Re: Re: Re: AR and BR's in reply to ERIC, 07-27-2004 18:56:02
Eric, use [email protected]. I don't know if I would buy a tractor on eBay. Email deeresofyesteryear, they will respond and get you pictures, I have emailed them before and they are firendly. Don't buy a tractor unless you can drive it around and try it out a bit. My philosophy is that a tractor that doesn't run is worth $.05/pound. I bought a book about restoring tractors by Spncer Yost and there is a picture of a wreck with a caption that ses "Don't walk away from a tractor like this - RUN!" This a correct statement, trust me. If you can't drive it onto the trailer, then you should be able to break open the piggy bank, pay for the tractor and still have enough for gas. Don't let anyone try to convince you otherwise. Your time is valuable.
Larry C
07-25-2004 19:49:59
Hey Eric. I have an AR in my two cylinder collection and it is my favorite. Its big and fun to drive and gets a bunch of questions and looks as you drive it anywhere. I paid 2700 for mine 5 years ago and have made the necessary repairs with new paint and decals...its a great looking tractor with great power..Larry
Gary J
07-26-2004 09:15:33
 Re: Re: AR and BR's in reply to Larry C, 07-25-2004 19:49:59
Were did you get your decal set for the AR? lots of a's
ERIC
07-26-2004 07:32:26
Is it a STYLED AR? Have any pictures of it? I saw a 1951 AR at a show this past weekend and thought that it would be nice to have one. We already have a 1935 John Deere B, BRASS tag, 4 bolt pedistal. And a 1943 Allis Chalmers C. We might get rid of that Allis so we can afford an AR. There aint nothing like the sound of a 2 Cylinder John Deere!
Thanks
ERIC
Dan
07-25-2004 19:45:06
BR's unrestored likely start at 4-5000,parts are a bit tougher to find,especially front steel,engine parts etc. Upside they are easy to store and always get approval at parades and shows,sheet metal is reproduced and available. Neat 15 hp tractor, around 3000 lbs.
Ralph
07-25-2004 18:56:39
I would estimate $2800 for a styled AR, weight 53-5500#, 39 HP on the belt, 35 on the drawbar. My manual is buried some place out in the shop. Essentially the same mechanicals as the A, but the test version of live hydralic introduced on row crops with the 50's and 60's. The row crop version (A or 60) though longer, will turn shorter. Easy (for an old geezer like myself) to get on. Excellent choice for pulling wagons, raking hay, towing a wagon filled with 1/4 acre of corn silage, but not 1/2 acre. Downside many (most?) were sold in the wheat growing (i.e. no row crops) areas of US and CA - Dakotas, SK Albert .. As a result many of them spent more time in third gear than all other gears put together (my conjecture). Might be a bit noisy in the high range as a result.
