4430 or 4230
Leo
07-24-2004 20:04:00
I am considering a 4430 or 4230 for some general farm work including moving big bales with a front end loader. Could someone tell me some basic differences between the two such as engine HP and cubic inches? Also, would the 4430 have a heavier front end that might be better for carrying bales on the front? Thanks.
4020dt
07-25-2004 06:55:27
 Re: 4430 or 4230 in reply to Leo, 07-24-2004 20:04:00
4430 has a larger fuel tank and radiator . Same 404 ci but has the inline Bosch inj pump which is far supperior to the rotary 4230 pump , heavier pistons and bigger air cleaner . Power train is pretty much the same for both I think . Usually there isn't much difference in price and sometimes a 42 will bring more than a 44 . Personally I would go for a 44 because they are a lot more tractor . Best 4430 would be a '76 or "77 model which is somewhere around serial #45000 and up , they had the latest power train updates in them . I don't know the serial ##'s on the 4230's but they would have the same updates at the same time .
John in Md.
07-25-2004 04:44:41
Both are 404's, 4430(125 hp) has turbo,4230 (100 hp) normal aspiration. The 4430 has higher compression due to positioning of rings on piston making it easier to start. If you are using them in the summer either one is good. If you are using year round go for the 4430, 4230's don't like cold weather, but love ether and loose top rings quick, then you need more ether, new starter and rings (if you can get one that's been rebuilt with the new style pistons they are better.)
JL
07-24-2004 21:44:32
They are both excelent chioces, but Id go with the 4430, for the power (140 hp) and the dependabillity and most of all the resale, seems like the 44 is always in demand, just keep it looking nice--jl
BW
07-25-2004 03:18:05
 Re: Re: 4430 or 4230 in reply to JL , 07-24-2004 21:44:32
Actually the 4430 is rated at 125 hp and the 4230 around 100 hp, I agree either would be good.
cat
07-24-2004 20:23:49
Same tractor. Same engine displacement. Different HP. Either will fit your needs well.
