Cheg, if you remove the plugs and turn her over and observe the spark, it needs to be a good highly visible BLUE, NOT a faint thin wimpy yellow spark. If you just use the plug wire ends and open her out to 1/8 or a lil more from them to the block, again a good blue spark is needed. Do you know where the mags run time advance is running????? it ought to be in the 20 to 30 BTDC range for good response. The mags rear coupler lag angle settign sets that, but a timing light is the only way to make sure where shes firign at under RPM (over 250) when the wind n trip srping is no longer operative. I guess you have checked the points gap on BOTH lobes and if the rotor bearign or bushing has wear n wobble try a wider points gap. The rotor and magnets need to be free of rust also and a weak rotor magnet can cause a weak spark also, it may need re magnetized. Coils or condensors can act up once up to temperature, if the sparks weaker when shes warmed up they may need some attention. Likewise, carbon or pitted points can act similar. They gotta be free of gray oxide and any carbon or pits etc. You goota use wire core wires also. Theres more but I gotta get ut to the fair, post back or e mail later if you need more help. Good luck n God Bless. John T
