4020 rear wheel width adjustment
gwece
07-24-2004 06:34:06
I just bought a 4020 and want to change the rear wheel width. Tires are moved almost inward as far as they will go and have appparently been set that way for a LONG time. I need them spread much farther apart for my hilly ground. I know the general procedure for moving the wheels (have done it on my 4010 years ago), but I also know they can be real hard to bust loose sometimes. Does anyone have any tips to pass on to make this a bit easier? (The 4020 has 3 sets of weights on each rear wheel....should I remove them before attempting to loosen wheel bolts?)
Thanks!
Huckleberry
07-25-2004 07:29:52
 Re: 4020 rear wheel width adjustment in reply to gwece, 07-24-2004 06:34:06
I had a similar problem with my 3020. Yes I would remove the wheel weights first. After loosening the bolts per operators manual I placed a hydraulic jack on the inside of the wheel close to the axle...that is sideways---then jacked out some...then I beat the end of the axle on the outside with a heavy sledge...then move the bolts that you have to turn some. Repeat this procedure until it finally breaks loose. some good thread cutting oil is also an effective penetrating oil. If you check the archives you might find where some other writer explained this better.
gwece
07-25-2004 09:17:41
 Re: Re: 4020 rear wheel width adjustment in reply to Huckleberry, 07-25-2004 07:29:52
Thanks for the info guys! I really appreciate it!
JMS/MN
07-24-2004 08:27:57
Find a pipe just slightly larger than the rear axle diameter, and long enough to extend past the end of the axle. Weld a 1/2 thick cover on one end of it. With a BFH you can loosen up the cones after moving the bolts.
