52A losing Power-Trol oil
CJDave
07-23-2004 23:22:36
Our 1952 A is transferring the Power-Trol oil to the gear case. What is the most likely cause of this oil leakage problem. This is a good-running tractor but sat for several years before we bought it.
Mick
07-24-2004 07:54:17
 Re: 52A losing Power-Trol oil in reply to CJDave, 07-23-2004 23:22:36
I had the same problem with my 48 ~A~, the PTO shaft mechanical seal was leaking, replaced the seals (and bearing since I was in there)and haven't had a problem since.
F-I-T
07-24-2004 05:24:59
CJDave:
The most common area for Powr-Trol to make its way into the rear end oil is via a blown cylinder to case gasket. In rare instances, there could be a crack. To repair you have to remove the rear end cover. Not a not job but a bit heavy and awkward.
Frank
CJDave
07-24-2004 05:56:20
 Re: Re: 52A losing Power-Trol oil in reply to F-I-T, 07-24-2004 05:24:59
Frank, is that still true if we haven't ever used the power lift? Only the remote cylinders on the 45 loader?
F-I-T
07-24-2004 06:32:18
 Re: Re: Re: 52A losing Power-Trol oil in reply to CJDave, 07-24-2004 05:56:20
Dave:
Yes. The last lime I had a bad leaker, it was my '48 A wearing a 45 loader and the loader would not stay up. Was a bad gasket.
CJDave
07-24-2004 06:39:51
 Re: Re: Re: Re: 52A losing Power-Trol oil in reply to F-I-T, 07-24-2004 06:32:18
Thanks for the help, Frank. Luckily my air conditioned shop is up and running now. I can see where I'll need an overhead hoist or at least one of those engine-pluckers that you see for sale in all the auto parts stores.
F-I-T
07-24-2004 06:41:56
 Re: Re: Re: Re: Re: 52A losing Power-Trol oil in reply to CJDave, 07-24-2004 06:39:51
Dave:
Yup, an engine hoist makes it not-to-bad- a task. In the old days, my dad and I did those by hand. Not fun. A third guy was needed to turn the pto shaft to get it to engage.
Frank
