Dist. Rotation speed on 52 A
Mike in AR
07-23-2004 19:36:41
Does the distributor on a 52 A rotate at half crankshaft speed? I think my cap is wrong.
John T
07-24-2004 06:31:12
 Re: Dist. Rotation speed on 52 A in reply to Mike in AR , 07-23-2004 19:36:41
Mike, What makes you think your cap is wrong?? Like Frank pointed out, most distributors (Delco or Wico) run direct off the governor shaft which is the same RPM as the Crankshaft. A few mags were gear reduction drive and drive at 1/2 crank speed, but many (like the Wico C or X) were also direct off governor and same as crank speed also.
With the cap off, see if the rotor is lined up with where the caps internal brass pickups would be when the points open????? When the points open on high cam is when the coil fires and when the rotor tip needs to be lined up with the brass looking terminal leading to the caps external plug tower. That would be so regardless if a full or 1/2 drive mag or distributor is used. Its where the caps internal pickup terminals are located that matters, not where the external tower is which could be internally wired/located elsewhere. You have your wires n the correct tower right???
Good Luck n God Bless
John T
F-I-T
07-23-2004 20:07:30
Mike:
The stock mag and distributor on an "A" turns at the crank speed, meaning it fires on the exhaust stroke as well as the compression stroke.
It would take a twice as large cam gear to step it down, and the the governor housing just wasn't made that big!
Now, there was a special distributor drive for the Delco distributor made for the factory LP Waterloos that some people have used, and the used a special cap that had the terminals sticking out vertical from the cap surface.
What sort of distributor do you have? Pretty sure the Wico X's used the same whether it was a mag or distributor. Wico C's only had one type.
Frank
