Backfiring from exhaust stack at idle
Frank in WV
07-23-2004 12:29:59
I have a 47 A that is backfiring up through the exhaust stack at idle. Do I need to retard the time some more? Do I have a possible valve problem? Points and condenser are new last year with less than 10 hours of run time, carb is rebuilt.
Daryl
07-25-2004 05:04:27
 Re: Backfiring from exhaust stack at idle in reply to Frank in WV, 07-23-2004 12:29:59
I had the same problem with an unstyled A. The carburetor was rebuilt and I even rebuilt the governor, but the problem was still there! I had all but given up and thought it must have needed a valve job. I let it set for six months or a year after it fouled a plug on me one day. After I changed the plug and got it started, I just happened to notice a little puff of exhaust smoke coming out around the idle adjustment screw. I tried some packing around it with no success. Next, I went and got an idle screw out of another carburetor. Started it up and it ran perfect! It was sucking enough air into the carburetor to make if backfire terrribly at idle. It ran good under load. This may not be your problem, but it sure gave me a headache for a long time!
