3010 throwout bearing
EJB
07-22-2004 21:29:55
I'm still working on this clutch job for my 3010. Thanks to everyone for the good advice so far. The manual says I have to take the clutch shaft out to get the throwout bearing off. This means separating the tractor between the clutch housing and transmission. I already have the tractor split between the engine and the clutch and would really rather not split it more. Can I get that throwout bearing off just by pulling on it while leaving the shaft and operating tube in the tractor? Any advice is appreciated.
Tom (Ks)
07-23-2004 18:14:42
 Re: 3010 throwout bearing in reply to EJB, 07-22-2004 21:29:55
Take a fair size hammer and tap on each side of the bearing and it should come off. You can drive the bearing and the tube off together and that's not good, the tube can be a problem to get back in again.
