1010 - how to remove right brake pedal to replace?
Cash Moline
07-22-2004 21:12:42
Hi...I bought a John Deere 1010 tractor that the right brake pedal broke on the old one which I guess has happened to a few people from searching the board. Found a 1010 parts tractor and got under there to take the old pedal off but cann't figure out how to get the big rod off or loose that the pedeal is attached to at the base? On the other side of this rod under the other side of the tractor it looks like some sort of set screw going into it. But I tried to put a wrench on it but its either round or the head is stripped or there is some other way to get it off - the other side of the screw on the other side of the rod is flush with nothing to grab on to at all? I have a 1010 IT shop manual but that doesn't tell or show-diagram me anything on this or the assembly. If the key is that set screw then maybe I'll have to figure out how to remove it or torch it off or? Thanks.
Cash Moline
07-23-2004 14:14:36
 Re: 1010 - how to remove right brake pedal to repl in reply to Cash Moline, 07-22-2004 21:12:42
Yes never had seen a snap ring before or how to remove it...I'm a amateur mechanic. :] The guy who just looked at it did say might need to heat it to remove it so it sounds like were on the right track and they said they'd have it off today.
Thanks for your help.
Cash Moline
07-23-2004 14:08:41
Found someone who took it off for $20 so thank you to those who emailed. If anyone needs a set of the 1010 front side panels (up by the front nose) for $50 delivered let me know.
-Cash M. in Austin, TX
Loren NC
07-23-2004 14:06:13
I don't understand exactly why you are trying to take the whole pin assembly. That rod you are talking about is grooved and the pedal is held onto it by a snap-ring. Why not just remove the ring and pull the pedal off? Of course, you could very well find it is pretty well stuck, in which case it will probably take heat to break it loose.
