Early B fuel valve
Rousseau
07-22-2004 17:11:22
I was wondering if these all fuel valves could be rebuilt.If they can is it hard to do.I have not taken it apart .Any help would be appreciated.
Thanks Rousseau Stevens
Mike M
07-22-2004 18:55:06
 Re: Early B fuel valve in reply to Rousseau, 07-22-2004 17:11:22
John Deere still sells these seals and Stephen Equipment sells reproduction valves if needed.
Rousseau
07-22-2004 18:27:52
Thanks Jon I will try that.It doesnt sound that bad.Thanks again Rousseau
Jon C
07-22-2004 17:57:49
The three way valve can be taken apart very easily. The nut just behind the lever (the only nut) simply unscrews from the body. The nut will slip over the lever and there will be a brass washer under that compresses the seal. The seal should be made out of a cork type material, and I have made new seals with cork/rubber type gasket material.
There is a cone shaped valve with 90 degree holes bored through it. I suppose you could use lapping compound to re-seal the cone piece to the main body if its really worn. But all I had had to do is make a new gasket with small scissors and a half inch hole punch, and re-assemble.
