'48 A First Reduction Gear Bearing noise
GeorgeK
07-22-2004 15:33:20
Anybody have any suggestions on replacing the first reduction gear bearings? I'd like to get my act together BEFORE I start taking things apart!
I have a squeeky/rumbley noise under load, or just going up a grade. I don't suspect it is the clutch bearings, but it might be. No noise with or without the clutch engaged while in neutral. I do feel vibration around the first reduction gear outer bearing cover, and know it (the outer bearing race) is kinda loose in the case cup.
Can you get to the inner bearing easily, or is this a major item that you have to pull the whole sliding gear shaft out to replace it?
I do have a parts book for the "A", and a Service Manual for the "B", and the tranny looks simular to the "B" for serial B96000 to B201000, so I can see about what I have to do, but any suggestions would be appreciated.
Thanks,
GeorgeK
Ralph
07-23-2004 17:31:28
 Re: '48 A First Reduction Gear Bearing noise in reply to GeorgeK, 07-22-2004 15:33:20
I had the same problem with my brothers A which is being rebuilt. The outer bearing race was loose. At one time an Iowa(?) company made a reamer and bushings to solve this problem. Fortunately the mechanic that helps me had a reamer and we used the last A bushing he had. Another route is to head to the salvage yard and obtain a better first reduction gear cover. I am enclosing my address above if you have further questions.
