4630 Air Conditioning
pbutler
07-22-2004 13:16:16
I have a 73' 4630 I bought a little over a year ago. Never have used the AC until last week-other than a quick check when I bought it.
It actually blows nice cool air for 10-15 minutes then it quickly warms and ends up blowing ambient temperature.
Any thougths?
I know very little about AC service but I do know I am not willing to put the $ in to take it to the shop, will probably suck it up and live without AC first.
I am considering one of those $40 "conversion" kits from Napa that has an oil compatible with R12 but have heard mixed reviews.
Paul
Jim B
07-23-2004 04:38:07
 Re: 4630 Air Conditioning in reply to pbutler, 07-22-2004 13:16:16
pbutler,if it has a heater as most I have seen does put a manual cutoff valve in heater hose to be sure that NO HOT water is ciculating.I had to do that on my JD 4255.I changed my tractor over to 134A and it cools better than it ever did on R12.Jim B
Lee
07-22-2004 16:36:07
I've spent many hours in a 4630 which does have a good full charge of R12 and a non-leaking compressor, it's adequate for the most part, but on the hottest of days it's just barely enough to keep you from kicking open the door. If I'm hired to drive it again, I'll convert it over to propane so that I don't wind up sitting in a pool of sweat for days on end like I always have done in the past.
You may have too much refrigerant in the system which is causing the high pressure switch to turn off the compressor once the system warms up to operating temperature. An iced over evaporator will just blow very little cold air, never warm ambient temp air - this is not the problem.
Your compressor is not turning is the problem, most likely an intermittent electromagnetic clutch, which can be changed, without releasing the R12 currently in your system. This will not be an easy to do and any hired mechanic will want to remove the R12 so he can take the compressor to the work bench to work on it - which means you'll have to buy the tools to replace the clutch and do it yourself with attached hoses if you don't want to also switch refrigerants at this time.
Overly sensitive circuit breaker can also cause the compressor to quit like this, once hot and kept hot by the engine it does not reset? A jumper wire and Volt meter applied correctly could show you exactly where the problem is. Don't overlook the thermostat switch here as possibly broken or just worn out with burnt contacts.
A $40 cheapo kit will do you no good without a vacuum pump and system flusher apparatus - I doubt you have either or can borrow same. The compressor will have to removed and flushed of all it's oil and the rest of the system has to be likewise 'cleaned' of any old oil. R134a reacts with that older type oil which is why the cheapo kit comes with it's own new type oil. Your last sentence makes no sense here, the old oil is not compatible with 134a, the new oil is compatible will all refrigerants, but does have a reputation for turning a non-leaking compressor into a leaker.
Before the rest of you all crawl on my case about propane, do a search for 'organic refrigerants' on google to learn for yourself that the EPA has a special class for them. They are ALLOWED. They do work. They work better than R12 or 134a. They are flammable - all of them. R12 when burnt creates phosgene (World War I nerve gas) just in case you thought you had been safe all these years past.
thurlow
07-22-2004 14:33:07
What kind of refrigerant is in it now??? If you can't tell, describe the "connectors" on the back of the compressor..... .Most of 'em "around here" have been converted to R134..... ...
buickanddeere
07-22-2004 13:27:30
Is the evaporator icing over?
pbutler
07-22-2004 13:29:50
 Re: Re: 4630 Air Conditioning in reply to buickanddeere, 07-22-2004 13:27:30
To be honest I am not sure. I will pop the top this weekend and let her run (need to clean out those drain tubes before fall anyway) and get back with you on that.
