Clooney....assistance needed on DTLX carb
Tyler in MO
07-22-2004 11:14:00
Hi Clooney...I have tried other avenues for help locally, however none have panned out for me. I have a 520 gasoline that has a carb issue.
It is from a dry part of the plains with little rust, carb appeared rebuilt. I tried it on the tractor and it won't run right. I've checked for air restrictions, clogged passageways, needles, jets, ect. The only thing that is obvious for me is the load screw. It will only thread in about 2.5 turns before becomming too tight to proceed. The threads appear good enough. I am wondering if there is any way to tell if the seat inside the housing is misalligned? Have you had any experiences with problems in this area of the carb? Any help would be great!
Thanks
Tyler in Missouri
