Adjusting distributor timing on a 47 A
Frank in WV
07-22-2004 09:42:03
Refresh my memory, do you turn the distributor towards the back to retard the time on distributor for a 47A? I'm backfiring periodically at idle and believe the time is a little to far advanced.
Frank in WV
07-22-2004 11:53:40
 Re: Adjusting distributor timing on a 47 A in reply to Frank in WV, 07-22-2004 09:42:03
Thanks John T. and Mike M.; I adjusted it a little the wrong way last night, I'll make a correction tonight.
John T
07-22-2004 10:26:28
Frank, the easy way to remember on those governor end flange mounts ignitions is they are turnign the same direction and RPM as the crankshaft, so to fire sooner you rotate them CCW or retard its CW.
CCW to advance, CW to retard.
At cranking speed (no advance) she ought to just fire the left cylinders plug as it passes TDC (just as points break OPEN), then 180 later the right plug. If the flywheels exposed, thats when its LHI mark passes by a flat mark on tractors side at 3 o clock (or dot on bottom hub center at 6 o clock lined with mark on cover bottom on some others).
Hope this helps
John T
Mike M
07-22-2004 10:11:20
I would say turning it back would advance it. I also would check and see how far off the timing marks it is now.
