1947 John Deere B
Larry C
07-21-2004 18:41:46
How big of a job is a manifold gasket replacement.My Model B was pulling when a bunch of steam came from around the manifold and most of the coolant leaked out. Thanks for any help..
Jon C
07-21-2004 19:23:06
 Re: 1947 John Deere B in reply to Larry C, 07-21-2004 18:41:46
Are you sure that its not the head gasket that is leaking coolant, rather than the manifold?
Larry C
07-22-2004 07:01:04
 Re: Re: 1947 John Deere B in reply to Jon C, 07-21-2004 19:23:06
Hey Jon C. Is there a quick and easy way to determine if its the head gasket or manifold? I had heavy steam coming from the top of the block around the manifold...thanks for your help
Jon C
07-22-2004 07:49:56
 Re: Re: Re: 1947 John Deere B in reply to Larry C, 07-22-2004 07:01:04
Well, if your B is anything like my unstyled B, I don't think water goes through the exhaust/intake manifold. The manifold is bolted to the top of the head with four studs and nuts on top. Right behind the manifold is the return water pipe that is bolted to the block with four bolts and a gasket.
Water does flow to lower part of the head, through the head and into the block than back to the radiator.
On my unstyled, its easy to see the edge of the head gasket , and since its right behind the exhaust manifold the heat from the exhaust may make it steam.
If your losing lots of water, something sounds fishy. Check your oil level and color. If its milky grey, and over full you have water getting into the oil which could also be the head gasket, or the push rod tubes. Post back and let me know and I will give you my 2 cents.
