Hard to start 37 B
Dick(Ind)
07-21-2004 18:11:34
It fires once then not again even if Ichoke it.If I pull it,it starts in 5 feet. What am I doing wrong?
John T
07-21-2004 21:05:08
 Re: Hard to start 37 B in reply to Dick(Ind), 07-21-2004 18:11:34
Hi Hoosier Neighbor, Well, if it fires once, that tells me your mag spring is likely okay, but it sounds like the other cylinder isnt firing maybe???? Often if someone tells me it will produce no spark at low cranking RPM, but starts n runs fine if pull started, I suspect a bad mag spring or the wind n trip coupler assembly. At over approx 250 RPM, the wind n trip is disabled and not needed to produce a spark as at crank speeds, thats why it can be bad but still run if pull started. However, from what you say, it sounds more like only one cylinder is firing which means its likely NOT a spring problem. (Althoug the trip dogs stil have to come out to wind the spring each 180, NOT just for one firing, but dependign on what mag you have)
What you gotta do is remove BOTH plugs and have the wires atached and the plug sides against the tractor frame for a ground, and insure BOTH produce a good visible blue and NOT a faint thin wimpy yellow spark. If you have a non gear reduction mag like a Wico C or X, every other plug will fire each 180 of flywheel rotation. If its a reduction drive mag like a Wico AP or some of the Fairbanks, the left plug will fire then the right 180 later, but then the left wont fire again until its next Compression stroke TDC. The non reduction gear mags like Wico C n X fire at BOTH TDCs, Power and Exhaust. Does the mag make a sharp loud SNAP or a faint dull clunk??? It needs to be a loud snap, but a weak spring may make less noise PLUS a weaker spark.
Other thigns that come to mind is that one side has a bad plug,,,,, or a bad plug wire,,,,, ,, or theres a cap or rotor problem if you have a situation where one side fires a good spark but the other does not despite a good loud mag snap.
You can do the both sides plug firing test as described above, and then swap plugs and plug wires etc to see if its a plug or plug wire problem or a cap or rotor problem. If you place a bare wire into each cap terminal and bend the ends to within 1/8 inch away from the mag or tractor steel etc, rotate the flywheel and see if BOTH produce a good similar spark. If they do but you get a weak spark at one sides plug, suspect the plug or plug wire. If one cap tower produces lesser spark than the other, suspect a cap or rotor problem. Remove the cap and check for cracks or carbon traces or a bad inner brass terminal or a bad or different rotor tip, depending on what mag you have.
If one cylinder is way lower on compression than the other, that can be a reason it isnt firing as strong at crank speeds also. If its rings are worn, a squirt of oil into the cylinders via the plug holes might make it fire better.
The staring technique and amount of choke can drastically affect starting, play with that n see what happens. Still, if she runs well pull started but it dont seem to fire BOTH cylinders when hand cranking, I would suspect a bad plug or a bad plug wire or a cap or rotor problem.
Maybe try a fresh set of Autolite 3077 plugs,,,,, ,good wire core and NOT carbon suppressor plug wires,,,,, ,,,insure the cap n rotor are clean and carbon and crack free and theres no difference in the caps internal brass pick ups or the rotor tips if you have a 2 tip rotor,,,,, ,,,,insure the points are gapped proper and NOT burned or pitted or carboned up or gray oxide coated,,,,, have clean fresh water free gas,,,,, ,experiment with different choke settings,,,,, ,,insure BOTH cylinders have good compression,,,,, ,,,see what happens????? ?
Thers more to say, but its late n Im tired, so let me know what you find and what mag you have and about the compressions.
Good Luck n God Bless
John T in Indiana
HAL
07-22-2004 06:14:39
 Re: Re: Hard to start 37 B in reply to John T, 07-21-2004 21:05:08
I agree with John T on the technique part I used to always give mine about 1/4 throttle and some choke but I have discovered with NO choke and basically no throttle it will crank on the second pull everytime.
John T
07-22-2004 06:38:47
 Re: Re: Re: Hard to start 37 B in reply to HAL, 07-22-2004 06:14:39
If yours starts that well with no choke, you gotta have a good engine, a good hot spark, good plugs, and a good carb for sure. On many of mine they need full choke for 2 piston compression pull overs, then back the choke off to 3/4 to 7/8, then they usually go.
John T
Jon C
07-21-2004 19:13:53
My guess is the mag. I'm far from an expert, but I think if you pull it, the trip and wind system is not needed.
Hopefully John T. will respond...he will outline the steps to go through, especially if its electrical.
(If John T., Clooney or others don't respond who are far smarter than me, I will post back and attempt to give you some ideas.)
