620 surging
AGR538
07-21-2004 14:47:56
My 620 two cylinder surges at high or low rpms, it doesn't matter. You can see the governor move the throttle on the carb up and then back. The only time it evens out is when it is under a load. Any suggestions would be appreciated.
bent
07-21-2004 15:10:06
 Re: 620 surging in reply to AGR538, 07-21-2004 14:47:56
There are lots of things to check, but before you tear your carb apart take a look at your governor spring. I had this same problem with a 60 and after taking the carb apart several times and replacing parts to no avail, I swapped the governor spring and it ran like a charm. If your spring is okay, try spraying ether or WD-40 and check for an air leak. Eliminate these two simple things first. Do a search on previous posts and you will get lots of information on what to check further inside the carb. Good luck.
Brent
