2510 Rear Arms
jdman(MO)
07-21-2004 14:14:46
Anyway to make those rear arms stay where you put them. Bought a John Deere rotary cutter, and it is impossible to use because if will not stay at the setting I put it at. You set it for say 4 inches and it will either go lower or higher. Russ
msb
07-21-2004 21:38:09
 Re: 2510 Rear Arms in reply to jdman(MO), 07-21-2004 14:14:46
Set the load and depth lever in the depth position.That should take care of the problem .
jdman(MO)
07-21-2004 21:51:56
 Re: Re: 2510 Rear Arms in reply to msb, 07-21-2004 21:38:09
If that is the 3 position lever on the right hand of the seat pedestal I tried that made things worse. In the bottom position the arms go fully up, and the lever on the dash has no effect. Also full down on the arms requires you only go to 3 on the cash lever. Russ
