G carb
John
07-21-2004 05:28:59
I have always wanted a model G. I see some are advertised as having a 'big nut carb'. What is the difference between the big nut carb and a regular one? How can you tell the difference by looking at them? Is the big nut carb better?
Roger
07-22-2004 17:57:01
 Re: G carb in reply to John, 07-21-2004 05:28:59
John, Dad's '51 G had a DLTX 71 carb from a late "A" on it for years & never hurt power at all, it now has a DLTX 108 U on it, I don't know if that's a carb specifically for "A"s or if that is a universal carb now but it runs fine with it
CMB
07-21-2004 06:17:31
The DLTX 51 (big nut),(all fuel) carb is original & correct for a styled "G". Some people , after installing high comp pistons, used a gasoline carb from a late "A" to try to cut fuel consumption. I have no info as to whether this hurt HP or cut fuel use. And yes, the bowl nut on a DLTX 51 is noticably larger.
