45A carb question
bullrunner
07-20-2004 20:46:31
Can I apply heat to the, what looks like brass screws that hold the float in the carb bowl? I want to inspect the float and clean everything while I'm in there. Those two screws don't want to budge. I've tried rust eater on them but have not had any success. I wasn't sure if the heat would effect anything else that I can't see at this time. Thank you in advance for the help.
John T
07-21-2004 06:36:02
 Re: 45A carb question in reply to bullrunner, 07-20-2004 20:46:31
I have used heat on those brass screws and others similar to them, ESPECIALLY the inner brass drill plugs which was absolutely necessary in order to extract them. Just go slow n easy n even in a circular motion with the tip of a small torch and dont overdo it. If you apply heat to them and the flame starts to develop any strange greenish yellowish orange funny color STOP, then when they cool a good sharp driver with plenty of downward pressure ought to do the trick.
Anywho, that has worked for me, (dont really know the physics n chemistry and if heat is proper on them or not???) it will be interesting to see other methods people use to extract them, as I have also found them to be very tight at times.
God Bless you and the others here
John T
