'49 A Bearing Question
Nick
07-20-2004 19:48:10
I am going to have my crank turned. I will be using the .020 undersized rod bearings. If I have the crank turned down exactly .020, will this leave room for some shims, or do I need to leave a few thousandths on the crank? Also, how much can the main journals be turned? There are no undersized bearings available for the mains. I do not want to turn it too much. Thanks for any help, Nick
msb
07-20-2004 21:28:42
 Re: '49 A Bearing Question in reply to Nick, 07-20-2004 19:48:10
Go to NAPA and get some Plastigage.You put a little piece of it inside the bearing and tighten the rod bolts.Then take the cap back of and measure the width of the plastigage with a piece of the package.IT is graduated as to how much clearance you have by how wide the plasitgage is crushed.The people who grind the crank should know what is should mic when it is .020 under but I would still check it withe the Plastigage.
