2010 timimg
david
07-20-2004 19:33:12
the original injection pump on the 1961 2010 JD finally locked up. the pump head seiged and twisted the pump driveshaft. rebuilt pump and put in the EXACT setting it came from.smokes and needs to be advanced more. Can the pin that holds the gear have sheared enough to keep the timing marks from lining up like they should? Can this be replaced by pulling the oil pan and pump?any help is appreicated. Thanks, david
msb
07-20-2004 20:56:32
 Re: 2010 timimg in reply to david, 07-20-2004 19:33:12
Its possible.I would be more concerned as to why the pump shaft twisted off.It is imperative that a fuel conditioner be used with that pump with the fuel we get today.See my comments(bob) at either tractor talk or tool talk concerning sulfur content in today's fuels.Don't remember the title but you should have no trouble finding it.Its only a couple days old.It takes a great deal of torque to twist off one of those shafts.So it could have partially sheared a pin it the gear although I have never seen it happen.If I were there,I could take a look and tell you without pulling the oil pump.You will have to pull both the oil pump and the injection pump unless you are extremely lucky. Did you get stuck with a new head and rotor too?Let us know what you find.bob
