FYI-Rubber for D steel
Steve
07-20-2004 19:08:29
Just thought some of you may like to know what I found fits front steel for the "D" I found that an upper variable cylinder drive belt from the 9000/9000-ten series combine turned inside out, hammers on to the wheel so snugly it doesnt even need bolts! Of course you want to use old belts unless you have $$ to burn. makes a nice looking rubber rib. Also, for the rears, the thick rubber strips from JD chaff spreader work well in a diagonal parallel pattern at 12 pieces per wheel.
