48 JD A Clutch
roscoe
07-20-2004 17:22:47
well I got the clutch pulley off and the bearing was bone dry.Repacked and was getting ready to put back on and noticed that one of the adjusting bolts was sitting down more than the others.well looking a little closer the ears were broke off of the piece where the bolt sat (not sure what its called).Does anyone know?Well going to call dealer tomorrow see if they have one. The flywheel is also loose(probably where alot of the noise is coming from along with the dry bearing).How do I tighten the flywheel?With the 2 bolts on each side of the shaft,then the big nut on the shaft or vice versa.Its not very loose, just enough to make a knock that I been hearing. Thanks for info....
Dave 2N
07-21-2004 04:07:42
 Re: 48 JD A Clutch in reply to roscoe, 07-20-2004 17:22:47
Roscoe-
The clutch on my 48 A was giving me fits-sometimes I couldn't engage it and other times couldn't disengage it. Also, couldn't get even tension on the adjusting bolts. Finally took the pulley off, checked it out, nothing seemed wrong, put it back on and still the same old problem. Took it back off again and put it on the bench; tried to comprehend why the operating sleeve slid sometimes and then sometimes didn't. As I sat there wondering and sliding the operating sleeve back and forth, I heard something drop out and hit the inside of the pulley. Well, it was an ear that had broken off one of the dogs and centrifugal force had wedged it between one of the adjusting bolts. Never so glad to see a broken part in my life!
Maybe this helps; hope so..
bob
07-20-2004 21:21:18
Wait till you get the clutch reinstalled and adjusted.Then set the endplay of the crank before you tighten the flywheel bolts.Set a dial indicator up on the outside of the flywheel.Pry the flywheel out .Denote the setting on the indicator and then engage the clutch.That will pull the crank toward the clutch side and then read the dial inficator.Unfortunately,I forgot what the endplay is set at.Maybe .003-.005?Then tighten the HE-- out of those big bolts.You may need to replace the thrust washer behind the left main bearing holder if you can't get it to adjust out.
F-I-T
07-20-2004 18:00:06
Roscoe:
I believe the part to which you refer is the clutch dog. P/N C 74 R is listed as available on JDPArts.com at a price of $49.86, though it always seems to be less when you ask the dealer. Not sure why.
Frank
