720 Diesel Motor
Warren
07-20-2004 17:13:49
Fuel injection pumps cover removed. On the back wall toward the crankcase are there two(2) small holes to spray oil out to lubricate the pumps or anything needing lubricated. If not, could this be a diesel fuel leak?
msb
07-20-2004 21:36:02
 Re: 720 Diesel Motor in reply to Warren, 07-20-2004 17:13:49
Nope.It is to lubricate the pump drives.Try to shield the oil from the front of the pumps and dry the delivery valve holders as good as you can and then run it and look for fuel at the delivery valve holders.Its the big nuts just behind where the injector lines attach at the pump rack.BUT DON"T STICK YOUR FINGER IN THERE WITH THE TRACTOR RUNNING!Shut it off before you check for fuel at the bottom of the holders.
F-I-T
07-20-2004 18:02:16
Warren:
I've only gone through a 70D, but do not remember two small holes that spray oil out. I think the cam lobes are used to fling oil out and into the pump compartment for lubrication, but I could be wrong. Be sure not to get you finger in front of a high pressure diesel leak. It can do some damage!
Frank
