Crank or Cam driven oil pump ?
5020Chris
07-20-2004 14:00:04
Do all 6531A engines fitted in the 6030's have cam driven oil pumps or were some fitted with crank driven pumps ? Its just I have been offered a good motor that would do as a spare and he says that its a crank driven pump and I don@t want to buy if it ain't goin to fit !
Thanks in advance,
Chris.
G-MAN
07-20-2004 15:54:13
 Re: Crank or Cam driven oil pump ? in reply to 5020Chris, 07-20-2004 14:00:04
I can't pull up my parts info to check right now, but having a cam-driven or crank-driven oil pump isn't going to have any effect on the external dimensions of the engine and where it will fit, if that's what your asking. If its a 6531A out of a 6030 and you want to put it in a 6030, it will bolt into a 6030 regardless of where the oil pump is driven from.
buickanddeere
07-20-2004 21:02:24
 Re: Re: Crank or Cam driven oil pump ? in reply to G-MAN, 07-20-2004 15:54:13
When looking at 531's and 619's. Which oil pump drive is prefered and are there other upgraded items to look for as well?
G-MAN
07-26-2004 07:44:50
 Re: Re: Re: Crank or Cam driven oil pump ? in reply to buickanddeere, 07-20-2004 21:02:24
I don't get to play with many of those bigger engines, but the crank-driven pump would be the preferred setup. Just like on the 400-series cam-driven pump engines, after a lot of hours and cold starts, the pump drive gear on the cam starts getting thin and can actually fail completely in some cases, which causes a loss of oil pressure and necessitates a cam replacement.
