Dan: It relaly is pretty straight forward, with the exceptions of things like a sticky oil slinger/spacer (directly behind the flywheel). Mine was so dog gone tight, I had to grab it with a strap wrench and tap-tap-tap it off the crank. No reason for it to be that tight, except to keep oil from migrating from underneath. Like I said, I made a spacer and it's a great thing. Since it appers you're starting from "scratch", you'll have to put the inner thrust washer on, then the thrust plate, then the outer thrust washer and everything else (HINT: Put a thin spot of grease here and there to keep the thrust washers from sliding out of position...not too thick so as to affect your readings). I'd try and set it initially on the low limit. I think it will get looser as it runs. Mine did. Use a torque wrench if you have one, though pretty much every one says they never saw one too tight. I put a little dot of finger nail polish at the intersection of the crankshaft splines and the flywheel hub to use as an indicator of movement. That's all I can think of for now. Maybe get new bolts as well. Frank
