Broke ANOTHER clutch Tbolt - JD B, HELP!!
RayP(MI)
07-19-2004 19:13:14
Have broken three tbolts in the clutch of my '49 JD B. two last season, and now one this summer. all broke while baling hay. Last summer with a Oliver T60, this year with a 268 Hayliner. (Assuming that the balers would have different rythms, and put different stress on clutch.) After the first one, I've been careful to not have the clutch extremely tight when engaged to latch, and have been very careful to have the tension on all three bolts even. All three have broken at the point where the threaded end meets the shank of the bolt - just where threads end. Any suggestions as to what I can do differently?
Those bolts are EXPENSIVE, and my supplier of used is out!
Ron
07-20-2004 09:23:59
 Re: Broke ANOTHER clutch Tbolt - JD B, HELP!! in reply to RayP(MI), 07-19-2004 19:13:14
I think the key here is that "all three have broken"....!! Now you have all New ones... You, I am sure, are not setting the clutch up TOO tight..just a nice "snap" is all that is required. Over the years we have broken one at one time or another, and it was just from normal use.. I guess they chrystalize after so much use, over time ..
Mike M
07-20-2004 06:19:52
I agree that this is VERY ABNORMAL.I would buy the new bolts as used ones may be fatigued. The only thing I can add is to double check by the book the placement order of those facings as I have seen some clutches with the facings in the wrong positions slip when under load.I would also think that you would tear up the pto or gears before the clutch as I have seen this plenty of times but never a clutch torn up and I have parted out plenty of these B's in the past.
Lee
07-20-2004 00:39:00
Your breakage is very abnormal? I would make my own, out of regular cheap bolts, first grade 5 and then grade 8 if grade 5 stretches or otherwise didn't do the job. There is no great stress that I know of here and so cheap grade 5 should manage just fine. I've never broken one of these bolts and I've had my 39 B for thirty years, 43 A for ten.
Your clutch should not be slipping even with a heavy baler load - is it? Water poured on the belt pully should not boil if the clutch is not slipping after a solid 30 minutes of heavy baler work. Water poured on the belt pulley should never boil. Once the clutch has been engaged there is no further 'stress' on it and it should not slip a bit even if the tractor is loaded to the point the engine dies suddenly.
It sounds like you are already doing everything right adjustment wise. You may have to do your clutch adjustment while very hot as an insurance maneuver unless you can point to a time in your tractor's history when these broken bolts could have been abused? Fatigue cracks can take years to fully ripen, even decades. Have any of the replacment bolts broken? If not, then your troubles may be behind you.
Perhaps the real solution is new clutch disks and/or have the coresponding metal parts surfaced?
RayP(MI)
07-20-2004 05:54:21
 Re: Re: Broke ANOTHER clutch Tbolt - JD B, HELP! in reply to Lee, 07-20-2004 00:39:00
Lee, thanks for the suggestion, but making replacements doesn't appear to be easy, due to design of blot - special head, threads substantially smaller than shank of bolt. Suspect that the bolts are a pretty good grade of metal, we had an old one around here for years that I used for a punch. Beat the dickens out of it, never showed any serious damage. We never had any trouble with our '47 B in the 34 years that we used it as the prime (only) tractor on this farm either. Have only had this '49 for a couple of seasons, but previous owner for 52 years was wife's uncle. Tractor probably not abused by him - very careful with his equipment. Didn't see much use in the later years. Clutch is clean, smooth, and works well. Clutch plates are, of course worn - as long as I'll have it down, I have ordered a set of new plates, and will be renewing them, but don't believe this is the problem. Clutch is not slipping noticably when engaged - even under heavy load. I'm out of ideas!
