Carbeurator on 3020U
farmerboybill
07-19-2004 19:00:07
I'm trying to get my Father in law's 3020 utility Gas tractor running. It's got spark and I bypassed the turpentine filled tank before the fuel pump and stuck a hose in fresh gas. When I pulled the plugs to check for spark I notice the plugs are dry. Thought it was good thing that meant I hadn't flooded it but now, since it won't pretend to want to fire, I think something must be funny with the carb. I drained the float bowl and turned the engine over until I got fresh gas but still no dice.
Someone told me the carbs on the new generation tractors weren't very good and also weren't fun to work on. He also said there was some sort of rubber diaphram in the float bowl that cracks up over time. I can't figure out why there would be a diaphram in the float bowl.
The only experiance I have with carbs are on small five horse Briggs engines. Does that qualify me to be able to tear this one down and put it back together properly? I'm terrified to tear into this one. Anyone have any low or no cost suggestions?
msb
07-19-2004 19:03:45
 Re: Carbeurator on 3020U in reply to farmerboybill, 07-19-2004 19:00:07
Whick carburetor does it have.The square boxy looking Marvel Schebler or the Zenith?
farmerboybill
07-19-2004 19:09:36
 Re: Re: Carbeurator on 3020U in reply to msb, 07-19-2004 19:03:45
I don't know. The fuel line comes in from the back and the air intake comes in from the front. The float bowl is bolted on from the top and has a plug in the bottom of it. I'll bet I'm being too general in my description but the tracor is 100 miles away right now. Sorry.
Another approach - it's an early 3020 as the hyd controls are on the dash.
msb
07-19-2004 19:37:18
 Re: Re: Re: Carbeurator on 3020U in reply to farmerboybill, 07-19-2004 19:09:36
Lucky you. its a Zenith.It does not have diaphram that rots.I would drain it and get a can of choke cleaner and fill the carb full with the little straw that comes on the side of the can.That can't hurt,might not help though.Let it set a while before trying to start it.Give the carb cleaner a chance to do some cleaning.There are lots of thing that could be the problem.The first thing I would check is to see if the choke is closing fully.Next, I would do a compression check to see that you don't have a sticking exhaust valve killing the manifild vacuum.
