8450 warning system
Herman
07-19-2004 16:17:28
On my 8450, the clutch temp light likes to come on intermittently and the engine temp guage likes to go up in the red. Both these conditions will cause the warning buzzer to go off as well as the orange question mark to light and sometimes the red stop sign to light. Turning the headlight switch full cloclwise and back to off will remedy these warnings, then a few minutes later, it does it again. The clutch or engine is NOT running hot, it is some type of electrical problem. I have run a 12 guage wire directly to the negative post on the battery to the ground bolt under the dash, thought maybe I had a ground loop. Can anyone help me. We have a 2750 that acts the same way on the heat guage, it reads too high, flick the light switch and the guage goes back to where it should. Our 4240 or 4640 do not have these problems, is this a 50 series problem?
Thanks to anyone for advice.
Herman in SK>
G-MAN
07-19-2004 16:20:42
 Re: 8450 warning system in reply to Herman, 07-19-2004 16:17:28
Check your harnesses for rubbed-through areas under the hood. On those old tractors, the plastic split-loom gets crusty and falls off and wires can start rubbing.
