JD 5200 clutch
H. Hull
07-19-2004 13:02:50
Im having trouble with my clutch not disengaging. If i push the clutch in sometimes it wont come out of gear and continues to move. I need help on what the problem might be and how to fix.
thanks
john-in-ga
07-19-2004 15:34:27
 Re: JD 5200 clutch in reply to H. Hull, 07-19-2004 13:02:50
Check your clutch linkage. I have a 5300, which I think will be same a 5200. Had similar problem after John Deere dealer did a recall fix. I found his mechanic had not properly attached the rod that goes up behind the dash. I thought at first I had a suck clutch. I checked the rod and found it loose on the end up under the dash. Reattached the rod and everything has been fine since. Hope that is your problem, as replacing those clutches can get pricey.
JDknut
07-19-2004 14:25:48
I had this happen on my 2350 MFWD last year and it ended up needing a new clutch, which cost about $700.00 which was not bad considering they had to split the tractor, install a new pressure plate and throw out bearing. A bad throw out bearing will do that, but by the time you open it to fix that, might as well throw in a new clutch and be done with it. It had 7200 hours on it at the time. Good luck.
