60 Carb
Maurie in MI
07-19-2004 12:10:51
Got the carb off of my 60 on the bench for some more cleaning and replacement of the bowl gasket. I was wondering about float adjustment. How do I know if it's set right. Never messed with it, but I want to make sure it's right before I put it all together and back on the tractor. Any help would be appreciated.
Maurie in MI
07-20-2004 12:14:57
 Re: 60 Carb in reply to Maurie in MI, 07-19-2004 12:10:51
Thanks Brent! The tractor wasn't running great, and I wanted to eliminate this as a possible cause. No sense putting it back together unless I know it's right.
Bent
07-20-2004 07:53:29
SM2000 says for a DLTX-81 carb to make sure that there is 3/4" from the bottom of the float (carb held upside-down with the needle seated) to the machined gasket surface on the body of the carb. If the tractor ran good before, your float is probably not far off this measurement.
Brent
