4020 engine ?
mike
07-19-2004 08:19:11
Had purchased a 4020D that I knew was seized up. Had removed exhaust manifold, and filled cylinders with diesel through injector holes.
Some antifreeze can out of oil drain plug. Filled coolant system with water and comes out of exhaust port for #1 front cylinder. Have not removed head yet. No water coming down in oil pan.
Any ideas or suggestions. I plan on rebuilding engine in future. Thanks
G-MAN
07-19-2004 10:40:14
 Re: 4020 engine ? in reply to mike, 07-19-2004 08:19:11
I agree with msb. This probably isn't going to be one of those "it was stuck but I got it broke loose and it runs fine now" situations. That works on some older tractors, but probably won't on this high-compression/high-speed diesel. Even if you did get it broke loose and running, there is likely enough cylinder and ring damage to make it run poorly, use oil and smoke. Take it apart, see what you're dealing with and go from there. If you're going to overhaul it later, there isn't much sense in putting a bunch of time and effort into getting it unstuck with it assembled now.
msb
07-19-2004 08:40:02
I wouldn't wait too long before tearing it down.Water and antifreeze can do a number on parts.Could cost you even more in the end.Even if you don't rebuild it right away,go ahead and get it taken apart and cleaned up inside.
