2510 help
jdman(MO)
07-19-2004 06:54:47
Just bought a 2510, and it looks like it has no high range. Reverses work good. Anything that can be checked without going inside the transmission. Russ
JDknut
07-19-2004 14:29:00
 Re: 2510 help in reply to jdman(MO), 07-19-2004 06:54:47
Might be a linkage problem. Check the adjustment using a service manual. A neighbor had this kind of problem with his 2510, but eventually he had to open up the tranny.
jdman(MO)
07-19-2004 16:44:13
 Re: Re: 2510 help in reply to JDknut, 07-19-2004 14:29:00
Thanks, finally found the other 4 gears, just worn a lot and takes a knack to get it in to high range. Also I am only used to 2 cylinder transmissions not this type. Russ
