Industrial Or Not?
Dan
07-18-2004 20:15:21
Ok I have a 1950 D and went i got it it was in its work clothes. Now i'm beging to restore it and as i was cleaning off the tractor under neith the green piant was some yellow.Now it was only on the govenor and the spline gear cover. Could there have put industrial parts on the tractor instead? My serial number is 188306.
Thanks
Brandon
07-18-2004 22:57:14
 Re: Industrial Or Not? in reply to Dan, 07-18-2004 20:15:21
Your tractor is most likely a normal green D. Deere used a yellow primer on some cast parts, and this is probably the source of the yellow you see. If the yellow was on the sheet metal, it would be a good bet that it was an "industrial" D.
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
