720 powersteering question
Steve
07-18-2004 19:11:07
My 720 has came without the top cap for the power steering. I have never seen one before. Does that top cap protect the reservoir from getting water in the system?
Next question... I guess assuming the answer above is yes... if there hasnt been one for many years how would we repair the damage from any water??
msb
07-18-2004 19:33:47
 Re: 720 powersteering question in reply to Steve, 07-18-2004 19:11:07
Remove the oil lines and then drain the reservoir at the bottom of the frame.Then flush it out real good with some solvent like mineral spirits.Drain it as good as you can and then use some compressed air to blow it out as good as you can.Hopefully, you will get most of the water, dirt,etc. out of it so that it will work.I would use it for a short while and then repeat the process.The other option would be to completely dissasemble it and clean it up.Yes , it had a filler cap at one time.
