Rack and Pinion
ags
07-18-2004 16:23:37
just got done pulling the wheels and getting into the rack and pinion rear wheel adjustment on a 1020. Of course it was all froze up with 30 years worth of corrosion.It was an all day job for two of us. I followed the instructions I found on this board got it all working. Thanks
I never did pull the pinion shaft or gear out. Has anybody done that?
msb
07-18-2004 19:43:45
 Re: Rack and Pinion in reply to ags, 07-18-2004 16:23:37
Sure, lots of them.Drive it out with a large hammer and punch after you have moved the wheel out enough to expose the teeth of the pinion.To reinstall the pinion using the same hex shaft, peen the 2 keyways just enough so that it will fit tight when it is driven back into the pinion or the shaft could fall out sometime later.
ags
07-19-2004 08:59:37
 Re: Re: Rack and Pinion in reply to msb, 07-18-2004 19:43:45
Thanks for the info. I thought it probably drove out,couldn't see anyother way it could come apart, but didn't want to beat on it without being sure
