1948JD A CLUTCH PROBLEM
Roscoe
07-18-2004 14:07:06
Need help getting bearing out to repak, on the clutch pulley.does the whole pulley have to come off to repak the bearing.what holds the pulley to the clutch lever?do i have to take the lever assembly apart too. any help would be appreciated.....FIRST TIMER
msb
07-18-2004 15:10:00
 Re: 1948JD A CLUTCH PROBLEM in reply to Roscoe, 07-18-2004 14:07:06
Remove the pin in the operating lever and all the bolts out of the plate behind the pulley and simply pull it off.There is a brass yoke that you will need to reinstall in the groove when you go back with the pulley so take a look as you pull the pulley.The bearing can then be driven out of the pulley assembly for repacking.You have taken the inner cast disk out haven't you? Takes 2 1/2" bolts to force it off the splined and tapered shaft.
roscoe
07-19-2004 09:00:39
 Re: Re: 1948JD A CLUTCH PROBLEM in reply to msb, 07-18-2004 15:10:00
The plate behind the pulley...meaning the plate where the clutch lever hooked to,or the big plate on the side of the tractor behind the pulley.I took the plate off the front of the pulley(where the clutch lever hooks,4 bolts)but the plate would not come out,nor the pulley come off.So I suppose you mean the big plate.To pull the big plate do I need to drain any of the fluids.Thanks for info.
