GP Tires
KS in OK
01-31-2004 06:18:36
I recently purchased a GP with cutoffs but no tires, could somebody tell me what size tires I need? Front and rear please, Thanks, KS in OK
Duane Larson
01-31-2004 13:26:47
 Re: GP Tires in reply to KS in OK, 01-31-2004 06:18:36
KS in OK,
GP cutoffs are found with 24", 26", and 28" diameter rears, so you will have to measure the rear rim diameter (bead to bead, not rim outside to rim outside), and the rim width from inside bead to inside bead. If we know those numbers we can recommend some rear tire sizes.
The fronts normally have 16x4.00 rims, so if that is the case, 6.00 x 16 tires would fit.
Marty Z
01-31-2004 07:25:37
OK here is what I have. Not sure if this is by the book
One tractor has 13 x 24 on rear cut offs and the other has 11 x 28 on cut offs. In my opinion the larger rim size looks better . It fills the fender better.
The front cut offs are both 7.0 X 16 tires.
Marty Z
