720 pony spark plug
Tracy Redd
07-17-2004 17:30:16
I have 720 std. diesel with pony motor. I have a lot trouble with installing a apark plug where behind the dsh. I tried to do it with dash off. Is there way make esier to instaall spark plug with dah off?
Thanks
Tracy
F-I-T
07-18-2004 08:46:14
 Re: 720 pony spark plug in reply to Tracy Redd, 07-17-2004 17:30:16
Tracy:
The other guys are right about how to go about it. I have used anything from a sheet metal socket cut off to fit, to a cut off box end wrench.
On the plug type, I have had best luck with Champion J-8-C.
I also run the pony engine from time to time after the main engine has warmed up so that I can burn off any crud in the pony. This seems to keep the plugs nice and clean. Those ponies spend nearly all their life starting off cold, so I like to give them good run when the coolant is 200*. That's where I tune mine up so that it will start hot and run well, which was always a problem for the ones I worked around yers ago. I find that even if I have to feed a bit of choke until mine is warmed a bit during a cold start, I know that it is running on the edge of lean and I can feather in richness from the choke this way. I think they keep cleaner plugs that way.
Frank
70D
07-18-2004 05:12:02
I know this is not right but I use the spark plug wrench that came with are 8N Ford it fits right down in the well I also take the starter pedal off and change it from the left side seem like it work better than in thing else that I have try I'm also going to swicth to autolite plugs for some reason I foul out about I set a champ plugs and I don't think its because I have the fuel to rich and I know its not oil so I'll swicth and see what happens
70D
buickanddeere
07-17-2004 20:48:52
Just use the box end of a standard combination wrench. Takes a while but they come out fine. Use a Autolite 216 for best results.
Blksmok
07-17-2004 18:45:49
Tracy...on my 70 diesels I always remove the starter to change the dash side plugs. It take a little longer to do it that way, but it's a lot less frustrating.
