JD 50-rear wheel screw jacks
Roger
10-22-2003 14:02:23
I'm working on the rear wheels on a JD 50. The two screw jacks are well rusted into the cast wheel. In fact I broke on of the screw jacks off while trying to remove. The wheel has now gone to a machine shop to remove both. My question is this. In the parts book it shows as part no. A4382 R . Jack screw 2 used (Sub.one A4882R and one A4883R ) Are these two jack screws different? they seem to be the same. Thanks, Roger
Clooney
10-22-2003 14:14:09
 Re: JD 50-rear wheel screw jacks in reply to Roger, 10-22-2003 14:02:23
Roger, the jack screws are the same,, that A4883R is the little snap ring that goes in the groove on the end of the jack screws to keep them from spinning all the way out.....
F-I-T
10-22-2003 16:05:45
 Re: Re: JD 50-rear wheel screw jacks in reply to Clooney , 10-22-2003 14:14:09
Clooney:
The screws have different numbers in the book. The first jack screw, A 4382 R, is used up to S/N 5016076 and is paired with snap ring A 369 R, and the second screw A 4882 R is paired with the later, heavier retaining ring A 4883 R. Likely the retaining ring groove is different than the early screw because I know that clip ring is wider and heavier, but the book calls them out as different. Now that I had a chance to think about it, the original ones had that flimsy snap ring, and people probably were loosing them as they worked out and over rode the clip. The later ones with that heavy clip stay in pretty good.
But they are different bolts, if only for the ring groove.
Frank
Clooney
10-22-2003 16:40:03
 Re: Re: Re: JD 50-rear wheel screw jacks in reply to F-I-T, 10-22-2003 16:05:45
Frank, it seems you & I deciphered his post differently.....
~The way I understood it he was asking if A4882R and one A4883R were different jack screws.
~I believe all the jack screws subbed to the later ones anyway...
F-I-T
10-22-2003 16:52:01
 Re: Re: Re: Re: JD 50-rear wheel screw jacks in reply to Clooney , 10-22-2003 16:40:03
Yes, I think that was the problem. He said "the screw is subbed to a yadda and a yadda, and are they the same screws?". I mean they are the function, but if he has an old snap ring it won't fit. But since he broke the screw, he'll get the 4882 and the retaining c-ring that you have to squeeze on.
I know on the 70 they had an R number and even those subbed to the new(er) screws with those big "C" rings, and all the 50/60/70/520-730 models used the upchanged screw. Looks like the number subbed when the upchange part came out on the -20 series.
F-I-T
10-22-2003 14:12:58
Roger:
I'm not exactly sure what the difference may be and it might be in the hardness.
My guess is that after having failing jack screws using the A4382 R on the 50/60/70, they upgraded to a better screw. In fact they went to a different one altogether on the 70.
