318 ignition controller
Tom
07-17-2004 13:59:40
I have a 318 lawn mower with eloctronic ignition. I need to install an ignition controller. Is this controller behind the flywheel and is this a big job to replace? Looks like you pull the rear shroud and drive shaft and flywheel, but not sure.
Any info would be very helpful,
Thanks.
John T
07-17-2004 14:07:08
 Re: 318 ignition controller in reply to Tom, 07-17-2004 13:59:40
Tom, I dont know beans about a 318, but I have a 110 and have gotten great help here over on the Garden Tractor Forum. Most mowers Ive owned only have a magneto or pickup/trigger coil under the flywheel, while controllers (solid state device to fire the coil) are usually externally mounted. I would ask on the Garden tractor Forum or get a manual before I pulled the flywheel, cuz Im not sure if theres anything behind there besides a coil or pickup/trigger coil???
John T
