2010 running hot
Rick
07-17-2004 11:32:50
When running implements off the PTO the temperature gage runs up to hot after about 10 minutes.
I have flushed the radiator and replaced the thermostat to no avail. Any suggestions?
Could the radiator cap not sealing properly cause this condition?
Thanks for any help you can provide.
buickanddeere
07-18-2004 23:34:47
 Re: 2010 running hot in reply to Rick, 07-17-2004 11:32:50
Depends on how hot that "hot" really is. Temperature gauges sometimes get tired with time.A really hot engine will "smell" hot". Can you get a candy thermometer into the flow from the engine at the top of the rad? Careful not to burn yourself.
msb
07-17-2004 16:14:31
Yes it could.What did you use to flush the radiator.It could still be limed up unless you used some serious stuff.Start it up with the radiator cap off and the radiator completely full.Do you see any air bubbles as it warms up?
Rick
07-18-2004 15:45:01
 Re: Re: 2010 running hot in reply to msb, 07-17-2004 16:14:31
Britt,
Thanks for the reply, I used Prestone radiator flush. I will check for bubbles as well as check the timing. What would bubbles indicate?
Rick
Britt
07-18-2004 07:25:34
You should also check the timing and the mechanical spark advance. Retarded timing can cause overheating.
Good Luck,
Britt
