3020-Really stuck in park
Dingaling
07-17-2004 10:54:43
Synchro range trans. Has been stuck before,but nothing I couldn't yank out. I broke the lever off of the shaft sticking out the side of the trans. housing. Mechanic told me to pull the detent spring and ball, did that and no help. We gave it a tug in each direction to no avail. Mechanic suggested taking top cover off and looking. I really don't know what to look for. I would really appreciate any insight you guys could lend,,,,, ,,Thanks D A L
DON
07-17-2004 17:43:34
 Re: 3020-Really stuck in park in reply to Dingaling, 07-17-2004 10:54:43
PULL HARD ON THE SHIFT LEVER UNTIL YOU CAN GET TO THE FIRST STATION. MOVE OVER TO THE GEAR SIDE AND PUT IT IN FORWARD OR REVERSE WHICH EVER GOES AGAINST THE LOAD AND LET THE CLUTCH OUT SLOW. TRACTOR WILL SNAP OUT OF PARK. THERE IS A HEAVY SPRING ON THE RANGE CHANGE LEVER THAT YOU COLAPSE TO MOVE OUT OF PARK POSITION.
