John Deere 40 Transmission stuck
B. Moon
07-16-2004 12:56:25
1954 JD 40s was not used for 2 weeks then trans. was inop, Pulled cover and output shaft and sliding gears are free. Can crank and engage clutch and it will not free up. Seems to be in either the input shaft of lower shaft, any ideas?
thanks.
B. Moon
08-30-2004 11:24:59
 Re: John Deere 40 Transmission stuck in reply to B. Moon, 07-16-2004 12:56:25
The problem was the (2)roller bearings for the 1st gear cluster were frozen in the input shaft, Removed gear, cleaned bearings and gear, problem solved.
James
07-16-2004 18:56:23
If you can crank it it prob. is in 2 gears at once so be careful or it will shell the teeth off.
Henry J
07-16-2004 14:47:42
B Moon
It sounds like you can crank the motor with the clutch in.
I would first doublecheck to make sure all the sliders are in the neutral position. With the cover off you should be able to rock the wheels back and forth and observe in the top to hopefully see something.
good luck and let up know
James
07-16-2004 14:22:43
Are you sure it is the trasmission and not the starter that is stuck? Check it out
