JD 60 Battery cables wiring harness
Russ M
07-15-2004 23:41:37
i have recently acquired a 1955 JD60 gas tricycle(#6046472) from my uncle's estate that needs a little electrical help. as the wiring has been "modified" over the years i need to start from scratch. i am planning to order a wiring harness rather than fiddle with the mess that is there. i thought i'd order battery cables too. my questions are: can anyone tell me or show me how the battery cables get to the battery under the seat? (wiring diagram or photos maybe?)i am sure how they are getting there now is wrong. The supplier is quoting $49 for a "cloth cable w/armor". is armor necessary? my IT manual, owners manual and all my picture books do not reveal the secrets! thanks in advance.
Russell
07-18-2004 19:01:05
 Re: JD 60 Battery cables wiring harness in reply to Russ M, 07-15-2004 23:41:37
I just changed my battey cable from the battery to the starter it cost me 17.00 for the cable and the connector from the starter, The post clamp was fine. I got the cable and end from an auto parts store. I think it was #2 gauge wire. It worked fine. I also have a 60. The Positive ground is hooked from the battery to one of the battery hold down bolts. I have a wiring diagram that i used to rewire the ignition but i dont have a way to post it on the screen. good luck
Russ M
07-18-2004 19:34:03
 Re: Re: JD 60 Battery cables wiring harness in reply to Russell, 07-18-2004 19:01:05
so does the cable from the battery to starter go underneath? mine right now comes out the top of the battery box, is just flopping around by my left foot and then sneaks into the top of the flywheel cover and goes down to the starter. it has been taped up pretty thickly where it passes the flywheel teeth cause it must rub there. this route doesn't seem right to me and i was wondering if it somehow goes underneath the tractor. what do you mean by "battery holdown bolts". is that inside the battery box in the seat? again my positive ground flops around by my right foot and is bolted down by the right brake pedal. again doesn't seem right. thanks for your help.
Russell
07-19-2004 19:37:34
 Re: Re: Re: JD 60 Battery cables wiring harness in reply to Russ M, 07-18-2004 19:34:03
The starter cable {negative post of the battery should start from the battery then goes out through the bottom front of the battery box into a recess in the cast iron of the rocksaft then down below the platform underneath the brake pedal then under the push button then is sneaked into the flywheel cover then goes behind flywheel where there is a steel clip that holds it away from the flywheel and connects to the starter stud. The positive cable goes from the + post down to the bottom of the battery box to one of the boxes mounting bolts to get a good ground. Look at the cast in the front of the rockshaft under the battery box the negative cable goes into the big recess and the coil wire goes into the smaller cable, this wire powers your lights and coil. Hope this helps.
