60 Brake adjusters broke!!
Fred from MO
07-15-2004 20:30:12
Ahh!. After soaking them in pen oil for a couple of days, then heat, too much muscle and snap I broke one adjuster. I believe the other is cracked as well. When I got the tractor the Left brake peddle was froze in the off position. After taking the drum off the pivot is froze on this assembly as well. Any suggestions on the broken adjusters and the frozen pivot. Boy this does not look like an easy fix.
F-I-T
07-15-2004 21:58:41
 Re: 60 Brake adjusters broke!! in reply to Fred from MO, 07-15-2004 20:30:12
Fred:
Well, the adjusters are still available from Deere. As to the rest, I prescribe lots of heat, then penetrant, then heat again, and repeat. I removed them best when everything is pretty near red hot.
Sorry it's not easier. You could cook them in an electrolysis tank for a week, and they might get better, but I'm betting you'll need heat.
Frank
