A hydraulics
Ron Sharpe
07-15-2004 19:36:06
I bought a jd 1219 moco and hooked it up to my 52 A and it wouldn't lift it off of the ground. is this normal ? Can i get enough pressure out of the hudraulics if i put washers behind the pressure relief spring
Mike M
07-16-2004 08:14:34
 Re: A hydraulics in reply to Ron Sharpe, 07-15-2004 19:36:06
I don't think it will work as that unit is made for tractors with 2200 psi.
buickanddeere
07-16-2004 07:55:46
Didn't the lettered series use the same 1200psi system the numbered series did? A larger cylinder should lift but may run out of oil unless a two line, down pressure system is used. As previously stated she will be slow lifting and a handfull to operate without power steering or live hydraulics and live pto. Pretty low on HP too.
Diesel Don
07-15-2004 21:31:37
The hydraulic pump on the A puts out about 750 PSI. I'm not familiar with your moco, but if you are trying to lift the unit with a 4" cylinder, the maximum lift will be on the blind end and will give you 9420# of lift. I don't know what the mechanical arrangement is for the linkage, but I would think that would be more than enough. The pump on your tractor may be worn, or the relief valve is not working correctly. Placing shims behind the relief spring will increase the pressure available, but if the pump is marginal, you won't see any inprovement. I would get a new spring and try that first. If that doesn't do the job, hook up a guage to one side of the lift cylinder and dead head it. If you read substantially less than 750 PSI, the pump is bad.
Ralph
07-16-2004 05:21:42
 Re: Re: A hydraulics in reply to Diesel Don, 07-15-2004 21:31:37
If you are trying to lift a J D 1219 for example, you will be way short of pressure. It seems to me they had a single 2" cylinder. I presume it was designed to be a fairly rapid lift, i.e. to get the cutter bar out of the cut hay at the end of the swath.
