14T Baler plunger/pickup drive bearing...
Tim
07-15-2004 19:20:08
Ok, we are making progress on this old baler!
I was able to run it today successfully hooked to the tractor, it ties on one side perfecly and was improving on the other...
Then a high pitched squeal started and I shut it all down and went looking for hot spots. Apparently the bearing for the plunger/pickup drive pulley has failed. It looks like there is a roll pin in the pulley that needs to be removed to get it off, does anyone recall if this is correct?
After that I assume getting the bearing off the shaft should be straightforward...right?
Thanks for all your help so far!
